How do we launch Edit UI of some feature in part from NXOpen
Siemens Genius Siemens Genius
Siemens Genius
I have custom blocksyler UI with treelist. Treelist is populated with some select features from current work part. When user selects some row in tree and clicks edit button on UI, I want to launch Edit UI of that feature, just as if user double clicked feature in part navigator.
Is there a way to acheive this?
SE-Advanced
Siemens Industry Software
Re: How do we launch Edit UI of some feature in part from NXOpen
The NX API in its current state does not allow you access to the standard NX feature dialogs.
