How to Automatically Run .DLL after Change Displayed Part command
I am trying to find a way to run a .DLL after a user changes their displayed part.
I tried using the User Exit, USER_CDISP, but that runs prior to the display part changing so my code is no good there. My code needs to change the new displayed part.
I tried looking for the command in the menuscript but I don't believe the right-click + Make Displayed Part is in there. If I could find that, I would do an ACTION/POST and that should get the job done.
Similar thread for reference: http://community.plm.automation.siemens.com/t5/NX-Programming-Customization/How-to-automatically-run...
Does anyone have any other ideas on how to possibly get this done?
DHuskic Nx 9
Re: How to Automatically Run .DLL after Change Displayed Part command
Denis,
Good morning. Assuming that you are also changing the work part when you change the display part, you can register a callback using UF_add_callback_function(), with a reason specified as "UF_change_work_part_reason".
This is prototyped in the uf.h header.
Best regards,
Steve
