How to Hide a NX Dialog?
I have a nxDialog created by using BlockStyler.I want to hide this dialog OR want to make this dialog invisible.Is it possible by programming?If yes,please let me know its nxopen api.
Re: How to Hide a NX Dialog?
Esteemed Contributor
Note the dialog would only be invoked by the user doing something (e.g. clicking on an icon that points to the dialog file).
What are you trying to achieve?
I have invoked a dialog using BlockStylerUI.
here is its sample code
theUI = UI.GetUI();
theDlxFileName = "boundingBox.dlx";
theDialog = theUI.CreateDialog(theDlxFileName);
theDialog.AddApplyHandler(new NXOpen.BlockStyler.BlockDialog.Apply(apply_cb));
theDialog.AddOkHandler(new NXOpen.BlockStyler.BlockDialog.Ok(ok_cb));
theDialog.AddUpdateHandler(new NXOpen.BlockStyler.BlockDialog.Update(update_cb));
theDialog.AddInitializeHandler(new NXOpen.BlockStyler.BlockDialog.Initialize(initialize_cb));
theDialog.AddDialogShownHandler(new NXOpen.BlockStyler.BlockDialog.DialogShown(dialogShown_cb));
I just Want to hide this dialog OR make it invisible though it is active.
Is it possible?
Why do you want to hide the dialog, I have never had a need to hide a dialog at all?
Manually you can click on the title bar of the dialog, which hides it in some way and you have to click the title bar again to show it, but I doubt this can be done in a programmatic way.
Still what is your work-flow with this dialog, that needs it to be hidden?
Production: NX10.0.3, VERICUT 8.1, FBM, MRL 3.1.4 | TcUA 10.1 MP7 Patch 0 (10.1.7.0) | TcVis 10.1
Development: VB.NET, Tcl/Tk Testing: NX12.0 Preparing: NX12.0
I want to invoke a custom  dialog .This dialog's life is linked to Nx Dialog.While custom dialog is in active state,Nx dialog also in active but it should be invisible or hidden?Thats why I want to know how to make NX dialog invisible or hidden.
You could just disable all the controls on the BlockDialog while your custom dialog is open..
Production: [NX8.5.3.3 MP11 64bit] Testing: [NX11.0.2.7 MP5] & [NX12.0.0.27 MP1]
There seems to be no way to do this, see Dialog box properties of the NX programming documentation, where only the label can be Set at runtime, everything else is Get, Initialize and Create only.
Why not integrate the second dialog into the first one each as its own group, so you can hide and show both groups at will?
