How to Refer a Part Attribute to Another Part
How to refer  a part attibute to another  part  attribute or to  cell text of table?
For a example   Part A has a attribute called  DesignContext which value is XYZ.
How to refer designContext attibute  to cell of a table of another Part B?
Sasikumar
Re: How to Refer a Part Attribute to Another Part
If the part is a component of the part that contains the table, this can be done.
If they are not part of the same assembly, this seems to be impossible.
Just to be clear: you have a tabular note in part B, one cell of which you want to reference the attribute value in part A (value: "XYZ")?
If so, you can do this with interpart expressions. Create an interpart expression in part B that references the attribute expression in part A.
However, maintaining interpart expressions can be tricky. The preferred method of referencing the attribute in part A would be with some "assembly/component" type of relationship as mentioned by @Stefan_Pendl .
Hi Stefan,
You are correct. Could you provide sample data , How to do the same what u said.
You just select the attribute in the column definition of the table column.
Hi stefan,
You  have mentioned as Table->Parts List.But I want to refer to a cell value of a table.
You can use any part attribute, since a component is just a NX object it is a regular object attribute.
It is like referencing an attribute in a drafting note.
