How to check if an CAM operation has instances
Esteemed Contributor
Is there no other way than using the CAM.OperationTransformBuilder to determine if an operation has instances or not?
Thanks in advance for any pointers.
Re: How to check if an CAM operation has instances
Beginning NX10.0.3 there is new API that allows the querying of an operation to know if
  • it is instanced
  • If so which operations are the instances
Mark Rief
Retired Siemens
Hi Mark,
long time no see Smiley Wink
Thanks for the update, I am looking forward to check this out.
I hope it is okay that I ressurect this old thread.
I am currently looking for a way to check if the selected operation is an instance or not.
Could you provide some codesnippets? I am using NX8.5.
I already took a look at the OperationTransformBuilder but I am not sure to get the infromation.
Thanks in advance
