How to check if tool path is edited without wrapper
Stefan_Pendl 3rd Gear
3rd Gear
Currently I use the following code of the UF wrapper to check if the tool path is edited, since I haven't found something pure .NET in the NXOpen API reference.
Dim theOperStatus As UFOper.Status1 = New UFOper.Status1
theUFSession.Oper.AskStatus1(theOperation.Tag, theOperStatus)
If theOperStatus.toolpath_edited = 1 Then
    ' tool path is edited
End If
Is there a new .NET method or property to use as a replacement?
Thanks in advance for any pointers.
Production: NX10.0.3, VERICUT 8.1, FBM, MRL 3.1.4 | TcUA 10.1 MP7 Patch 0 (10.1.7.0) | TcVis 10.1
Development: VB.NET, Tcl/Tk Testing: NX12.0 Preparing: NX12.0
Re: How to check if tool path is edited without wrapper
If you are looking for the operation edit status, I think CAMObject.Status is it:
Member name Value Description
Complete 0 Object path has been output
Repost 1 Object path must be post-processed
Regen 2 Object path must be regenerated
Approved 4 Object path has been approved as is
If you are looking for the path status (generated, imported, edited, empty, ...) I will need to dig deeper.
Mark Rief
Retired Siemens
3rd Gear
Hi Mark,
yes I know about the operation status, but I really need the status of the tool path.
I also have tried various searches in the NXOpen API reference, but found nothing except the UF wrapper.
Thanks for taking a look into this Smiley Wink
The UF wrapper is the only way now. We'll try to get the .net in NX 12.
Mark Rief
Retired Siemens
3rd Gear
Hi @MarkRief,
thanks for trying to get ,NET wrapper-free Smiley Very Happy
You can track with PR 8852262.
Mark Rief
Retired Siemens
3rd Gear
Thanks @MarkRief, I have created an IR to get connected to the PR listed above.
