How to choose the Maximum Scope for Specify Point Blok UI
I need to select a center point of some holes in an assembly but the Specify Point Block does not have MaximumScope to select Entire Assembly in Nx10.0.2.6  v1.0.0 of Block UI, is there other way to select center point of circle or hole? how i can deactivate Scope?
Re: How to choose the Maximum Scope for Specify Point Blok UI
I tried with Propery List
 PropertyList pl.....;
pl.setEnumAsString("MaximumScope", "Entire Assembly");
but it does not work on "SpecifyPoint", it shows me a this mgs
Issue: "Invalid property name for the block. See syslog for details"
Smiley Frustrated
