Do you mean
Reply
Solved! Go to solution
How to delete unnecessary objects in detail view?
I met a problem that when I create a detail view, I found the detail view will get a copy(object,like line, arc, group) from parent view, I don't want it. Is there any way to delete these unnecessary objects or maybe there is a way when I create a detail view could leave these object which I don't want?
I use  VB .Net to programming under NX10.
Thanks in advance!
Best Regards
Christian
Re: How to delete unnecessary objects in detail view?
[ Edited ]
I found way to delete unnecessary objects in the drafting view.
Best Regards
Christian
Solution
Solution
Accepted by topic author Christian0313
‎03-23-2017 04:21 AM
[ Edited ]
draftingView.Expand()
Dim tag2() As NXOpen.Tag = Nothing
Dim tag1 As NXOpen.Tag = NXOpen.Tag.Null
Dim groupTag As NXOpen.Tag = NXOpen.Tag.Null
Dim allGroups As ArrayList = New ArrayList
Dim n_visible As Integer
Dim n_clipped As Integer
Dim clipped() As NXOpen.Tag = Nothing
theUFSession.View.AskVisibleObjects(draftingView.Tag, n_visible, tag2, n_clipped, clipped)
For z = 1 To n_visible
Try
theUFSession.View.CycleObjects(draftingView.Tag, UFView.CycleObjectsEnum.DependentObjects, groupTag)
Catch ex As Exception
End Try
Try
theUFSession.Group.AskGroupOfTag(groupTag, tag1)
theUFSession.Obj.DeleteObject(tag1)
End Try
Next
Best Regards
Christian
