How to differentiate between "WORKPIECE" & "HOLE OR BOSS GEOMETRY"
 I use the following to differentiate between featureGeometry and orientGeometry:
 if TypeOf ncGroup1 is CAM.featureGeometry then
elseif TypeOf ncGroup1 is CAM.orientGeometry then
endif
Then, how to differentiate between "WORKPIECE" & "HOLE OR BOSS GEOMETRY" as both are featureGeometry?
LIM
NX 10.0.1.4, WINDOWS 7
NX 10.0.3.5, WINDOWS 7
Re: How to differentiate between "WORKPIECE" & "HOLE OR BOSS GEOMETRY"
Esteemed Contributor
I always use theNCGroup.GetType().ToString(), since that should return "NXOpen.CAM.HoleBossGeometry", etc.
Production: NX10.0.3, VERICUT 8.1, FBM, MRL 3.1.4 | TcUA 10.1 MP7 Patch 0 (10.1.7.0) | TcVis 10.1
Development: VB.NET, Tcl/Tk Testing: NX12.0 Preparing: NX12.0
hi stefan,
Thanks for your reply, but it return the same type for either one.
I have tried this:
Dim ncGroup1 as CAM.NCGroup = CTYPE(workpart.CAMSetup.CAMGroupCollection.Findobject("WORKPIECE"),CAM.NCGroup)
lw.Writeline("Geometry = " + ncGroup1.name + " , type = " + ncgroup1.gettype().tostring())
the output:
   geometry = WORKPIECE , type = NXOpen.CAM.FeatureGeometry
when I change the "WORKPIECE" to "HOLE_BOSS_GEOM" it gives:
   geometry = HOLE_BOSS_GEOM , type = NXOpen.CAM.FeatureGeometry
It still show FeatureGeometry for both "WORKPIECE" and  "HOLE_BOSS_GEOM"
any clue?
THANKS
LIM
Are you sure the WORKPIECE is a mill_geom group, and not a renamed hole boss group?
Go to create geometry, and create new WORKPIECE and MILL_GEOM groups (they shoul dbe identical), and then run your program.
Hi Mr.Mark,
I created the geometry using the hole_making template's Geometry subtype "WORKPIECE" and "HOLE_BOSS_GEOM" with the default name "WORKPIECE" and "HOLE_BOSS_GEOM" respectively.
Please refer to the picture I have attached.
LIM
NX10.0.1.4, WINDOWS 7
here is my codes:
' NX 10.0.1.4
' Journal created by sclim on Tue May 24 09:06:38 2016 Malay Peninsula Standard Time
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main (ByVal args() As String)
Dim theSession As NXOpen.Session = NXOpen.Session.GetSession()
Dim workPart As NXOpen.Part = theSession.Parts.Work
Dim displayPart As NXOpen.Part = theSession.Parts.Display
        Dim lw As ListingWindow = theSession.ListingWindow
        lw.open()
'   Menu: Insert->Geometry...
Dim nCGroup1 As NXOpen.CAM.NCGroup = CType(workPart.CAMSetup.CAMGroupCollection.FindObject("GEOMETRY"), NXOpen.CAM.NCGroup)
Dim nCGroup2 As NXOpen.CAM.NCGroup
nCGroup2 = workPart.CAMSetup.CAMGroupCollection.CreateGeometry(nCGroup1, "hole_making", "WORKPIECE", NXOpen.CAM.NCGroupCollection.UseDefaultName.True, "WORKPIECE")
        lw.writeline(" geometry name = " + nCGroup2.name + " type = " + nCGroup2.gettype().name)
Dim featureGeometry1 As NXOpen.CAM.FeatureGeometry = CType(nCGroup2, NXOpen.CAM.FeatureGeometry)
Dim millGeomBuilder1 As NXOpen.CAM.MillGeomBuilder
millGeomBuilder1 = workPart.CAMSetup.CAMGroupCollection.CreateMillGeomBuilder(featureGeometry1)
'   Dialog Begin Workpiece
Dim nXObject1 As NXOpen.NXObject
nXObject1 = millGeomBuilder1.Commit()
millGeomBuilder1.Destroy()
'   Dialog Begin Create Geometry
Dim featureGeometry2 As NXOpen.CAM.FeatureGeometry = CType(nXObject1, NXOpen.CAM.FeatureGeometry)
Dim nCGroup3 As NXOpen.CAM.NCGroup
nCGroup3 = workPart.CAMSetup.CAMGroupCollection.CreateGeometry(featureGeometry2, "hole_making", "HOLE_BOSS_GEOM", NXOpen.CAM.NCGroupCollection.UseDefaultName.True, "HOLE_BOSS_GEOM")
        lw.writeline(" geometry name = " + nCGroup3.name + " type = " + nCGroup3.gettype().name)
Dim featureGeometry3 As NXOpen.CAM.FeatureGeometry = CType(nCGroup3, NXOpen.CAM.FeatureGeometry)
Dim holeBossGeometry1 As NXOpen.CAM.HoleBossGeometry
holeBossGeometry1 = workPart.CAMSetup.CAMGroupCollection.CreateHoleBossGeometryBuilder(featureGeometry3)
Dim geometrySetList1 As NXOpen.CAM.GeometrySetList
geometrySetList1 = holeBossGeometry1.FeatureGeometry.GeometryList
Dim geometrySetList2 As NXOpen.CAM.GeometrySetList
geometrySetList2 = holeBossGeometry1.FeatureGeometry.GeometryList
Dim nullNXOpen_CAM_CAMFeature As NXOpen.CAM.CAMFeature = Nothing
Dim featureSet1 As NXOpen.CAM.FBM.FeatureSet
featureSet1 = holeBossGeometry1.FeatureGeometry.AddFeatureSet(nullNXOpen_CAM_CAMFeature, "NXHOLE")
holeBossGeometry1.FeatureGeometry.SetDefaultAttribute("IS_THROUGH", 1)
geometrySetList2.Append(featureSet1)
featureSet1.AngleToleranceEdges = 0.0
featureSet1.Intol = 0.0
featureSet1.Outtol = 0.0
'   Dialog Begin Hole or Boss Geometry
Dim nXObject2 As NXOpen.NXObject
nXObject2 = holeBossGeometry1.Commit()
holeBossGeometry1.Destroy()
        lw.close()
'   Menu: Tools->Journal->Stop Recording
End Sub
End Module
