How to enable the BlockID property in Block UI styler design
I am not seeing the BlockID property in the Block UI Styler design window
1. Go to Block UI Styler application
2. Add any control and see the property dialog where there used to be a BlockID property where you can change the default ID name to meaning full name for example : from "button0" to "btnCreateBlock".
3. It does appears in the Teamcenter - NX
Does anyone know the settings?
Thanks in advance
Re: How to enable the BlockID property in Block UI styler design
Esteemed Contributor
I think this has been removed in NX 10, I am able to access it in NX 8.5 Smiley Sad
We will have to create a problem report for this regression.
I have rechecked with NX 10.0.2 and the block ID can be accessed again, so this was only a regression in NX 10.0.1 Smiley Wink
Thanks for the information, I will check it in NX10.0
