cancel
How to execute .pyc file in NX11
Hi All,
I want to execute compile .py file(.pyc) in NX11 same as .dll file but I am not able to use this cpython compiled file.
Saddam
Re: How to execute .pyc file in NX11
Right - to run NXOpen Python programs, you will need to do it from the Journal Manager dialog.  Here is a note about this from the NX 11 NX Open Programmer's Guide:  "NX Open for Python does not use a compile and link development cycle to develop applications. NX Open Python journals are executed in NX through journal replay, either using the Python interpreter packaged with NX or an external Python interpreter provided in your environment. Check the Release Notes for details on the Python environment required for executing NX Open Python journals."
