How to extract the Faces and Feature suppressed
Hello All, I would like to know how to extarct faces of 3d model and how would we come come to know that whether the feature is suppressed or not in 3d model using NX OPEN VB.NET
Rupali
Re: How to extract the Faces and Feature suppressed
If you have a reference to a feature object, you can use its .Suppressed property to determine if it is suppressed or not.
If you have a reference to a body object, you can use its .GetFaces method to get references to the faces contained by the body. If you need to create an "extract face" feature, record a journal of the process to see what code is needed (then modify the code to your needs).
