How to get 2D associative point of dimension
Hello All,
I was trying to get two associative point of any dimension.
I used-
Dim dim1 As Annotations.Dimension
Dim firstpoint As Point3d = dim1.GetFirstAssociativity.PickPoint
Dim secondpoint As Point3d = dim1.GetSecondAssociativity.PickPoint
But it returns point3d from modelling. I want points of drafting sheet.
How will I able to get that?
Please help.
Abhi
Betreff: How to get 2D associative point of dimension
Use:
UF_VIEW_map_model_to_drawing
Jan
Jan Böttcher
It works perfectly.
Thank you so much Jan.
