How to get Start and End points of all the drafting curves which are present in a view Using NX Open
Hello All.
How to get Start and End Points (x,y) of all the drafting curves which are present in a a drafting view using NX Open Programming.
I could able to get what kind of Curve type is, but not start and end points.
Kind Regards
Praveen.
Re: How to get Start and End points of all the drafting curves which are present in a view Using NX
Check out the NXOpen Evaluation section.
 Based on your curve type, you can call the regarding functions
UF_EVAL_ask_arc
UF_EVAL_ask_line
to retrieve the curve start and end points.
You can use UFSession for this.
Just look into "ufs.Modl.AskCurveProps" in reference guide.
Using it you will be able to get startpoint as well as endpoint.
Hope it helps.
Abhi
