How to get all unique part and sub assembly from main assembly in NX7.5
Hi All,
I need count of all unique part and sub assembly of any Assembly file through VBA/VB.Net.
Ex. Let Suppose i have an assebly naming Assembly1. Assembly1 Contains both part file as well as sub Assembly file. Then,
Dim Count_Part As Integer  = count of unique part file present in Assembly1
Dim Count_SubAssm As Integer = Count of all unique sub assembly file present in Assembly1
Any help would be greatly appreciated.
Re: How to get all unique part and sub assembly from main assembly in NX7.5
Here's an example:
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Imports NXOpen.Assemblies
Imports NXOpen.UF
Module Module1
    Dim theUfSession As UFSession = UFSession.GetUFSession()
    Dim lw As ListingWindow = theSession.ListingWindow
    Dim uniqueParts As New List(Of Part)
    Dim uniqueSubAssemblies As New List(Of Part)
    Sub Main()
        If IsNothing(theSession.Parts.BaseWork) Then
            'active part required
            Return
        End If
        Dim workPart As Part = theSession.Parts.Work
        Dim dispPart As Part = theSession.Parts.Display
        lw.Open()
        Try
            Dim c As ComponentAssembly = dispPart.ComponentAssembly
            If Not IsNothing(c.RootComponent) Then
                reportComponentChildren(c.RootComponent)
            Else
                lw.WriteLine("Part has no components")
            End If
        Catch e As Exception
            theSession.ListingWindow.WriteLine("Failed: " & e.ToString)
        End Try
        lw.WriteLine(dispPart.FullPath)
        lw.WriteLine("count of unique sub-assemblies: " & uniqueSubAssemblies.Count.ToString)
        For Each temp As Part In uniqueSubAssemblies
            Try
                'may throw an error if the file is not loaded
                lw.WriteLine("  " & temp.FullPath)
            Catch ex As Exception
            End Try
        Next
        lw.WriteLine("")
        lw.WriteLine("count of unique parts: " & uniqueParts.Count.ToString)
        For Each temp As Part In uniqueParts
            Try
            End Try
        Next
        lw.Close()
    End Sub
    Sub reportComponentChildren(ByVal comp As Component)
        For Each child As Component In comp.GetChildren()
            Dim thePart As Part = child.Prototype.OwningPart
            If child.GetChildren.Length <> 0 Then
                '*** this is a subassembly, add code specific to subassemblies
                If Not uniqueSubAssemblies.Contains(thePart) Then
                    uniqueSubAssemblies.Add(thePart)
                End If
                '*** end of code to process subassembly
            Else
                'this component has no children (it is a leaf node)
                If Not uniqueParts.Contains(thePart) Then
                    uniqueParts.Add(thePart)
                End If
            End If
            reportComponentChildren(child)
        Next
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image immediately after execution within NX
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
Thank you so much for the code.
