How to get\fetch checkmate results through NXOpen.
Siemens Genius Siemens Genius
Siemens Genius
Hi All,
The problem I am facing to fetch the checkmate results from nx-part though NXOpen, I already tried out one solution from GTAC solution center (example) but not succeed.
steps done:
1. launch nx and open part having few solid bodies,
2. run all default check available in modeling option,
3. save the part.
4. run the NXOpen program to get the results of all the checks,
but it returns nothing and all available checks in HD3D navigator are gone.
Please let me know what went wrong OR I missed any step.
Rajendra
NX1201, NXOpen language: VB.net
3 REPLIES 3
Re: How to get\fetch checkmate results through NXOpen.
Siemens Genius
Are you sure the check results are being saved into the part file? ie save_log_in_part: True;
Siemens Genius
Hi @AdyBA86,
Thank you for your replay.
here I have running the default checks availble in modeling category (all are not editable) then saved the part interactively and then try to get the results using above NXOpen program. as I am not much familiar with check mate so let me know if I missed any step here.
Thanks again,
Rajendra
Siemens Genius
Choose the 'Check Blend/Chamfer Referencing' check as a test. (This is set to 'Save Log in Part').
Under the Run Options tab set 'Save Part After Checking' to 'Always Save'. Execute the test.
This should save the results to the part file which then should be seen by your NX/Open program.
Any better?
