How to get light source color?
Hi!
In "Advanced Lights" dialog I can customize a color of a light.
How do I extract it via API?
NXOpen::Light interface doesn't have any corresponding methods...
Thank you in advance
Re: How to get light source color?
What version of NX are you using?
The NX 11 API docs state (LightType enumeration):
For now, you can only modify lights of type LightType.Scene via automation languages.
and it looks like you can only change the intensity of the scene light:
For now, setting Light.Intensity may only be used for a scene light.
I don't want to changed it.
How do I GET it?
