cancel
How to get nx11 bitmap library files or name?(etc, nx10, nx9,...)
Hi.
I want to get the icon files(bitmap) used by NX.
for example
NX_75_Bitmaps_Misc_Icons.zip
NX_75_Bitmaps_16x16.zip
NX_75_Bitmaps_24x24.zip
NX_75_Bitmaps_32x32.zip
NX_75_Bitmaps_48x48.zip
or
I want to get a reference to the bitmap name used in the block styler.
for example. 'select_face', 'select_body', ...
Betreff: How to get nx11 bitmap library files or name?(etc, nx10, nx9,...)
For the names of the NX dialog bitmaps see this discussion:
https://community.plm.automation.siemens.com/t5/NX-Design-Forum/NX-10-0-Bitmaps/td-p/348419
Jan
Jan Böttcher
Re: How to get nx11 bitmap library files or name?(etc, nx10, nx9,...)
Also take a look in Solution Center at document
Getting Started with NXOpen : Using standard NX bitmaps in custom dialogs
https://solutions.industrysoftware.automation.siemens.com/view.php?si=nx_api5349
Thanks. Smiley Very Happy
to findout what an icon name is
1) right click in the menubar area --> Customize or use the shortcut Ctrl+1
2) right click on an icon --> Change button icon -->  Icon name
