How to get "Direction" from workPart.
I want to get the directions from workPart. Plz. help for the same.
Here in Journal it represent like this:
NXOpen.Direction direction1 = (NXOpen.Direction)workPart.FindObject("HANDLE R-1940");
measureDistanceBuilder1.ProjectionVector = direction1;
But i want this without passing Journal String.
Thanks in advance.
Re: How to get "Direction" from workPart.
Use the Directions property of the Part object.
Jan
Jan Böttcher
Create a new direction object with the properties that you need.
Are you creating an associative measurment feature? Create an associative direction object for the feature to reference.
Performing a non-associative measurement? Create a direction object without parameters and NX will clean it up later.
