How to get selected CAM Operation while running Blockstyler GUI
Hello everyone,
I am trying to run the Postprocessor out of a Blockstyler GUI.
I tried to fetch the selected Operation with this code:
objects1(0) = CType(theUI.SelectionManager.GetSelectedObject(0), CAM.NCGroup)
If I run the journal directly it works perfect. If I attach this code to the Blockstyler Button,
it throws an "internal memory access violation".
Does anyone have a suggestion how to solve this problem?
Edit: I am using NX8.5
Best Regards
Re: How to get selected CAM Operation while running Blockstyler GUI
GetSelectedObject is not an array or do you use GetSelectedObjects() ?
In addition I would fill a variable and test if it is nothing and if not check the type of the object contained.
Additionally the ONT is not fully supported by the SelectionManager prior to NX 10, so it would be better to use the UF wrapper for AskSelectedNodes.
thanks for the help! I will try it as soon as possible :-)
To see some samples, look in UGOPEN\SampleNXOpenApplications\.NET\CAM for *OntSelection.vb. These programs are run after the user has selected nodes in the Navigator.
Mark Rief
Retired Siemens
Hello again,
Tried to figure out how to use the wrapper, but failed... Smiley Frustrated
Maybe someone could give me a little hint or a basic line I can modify.
Also something I try to understand:
If I call the post processor run with CAMSetup.Postprocess or CAMSetup.PostprocessWithSetting and the Postprocessor run onto an error, it will throw the errormessage "User aborted operation" instead of the errormessage which the postprocessor throws. Is there also a way to fetch the 'correct' error message?
Thank you again all for the help,
I really appreciate it!
WT wrote:
Hello again,
Dim tSelectedNodes As Tag() = Nothing
Dim iNodeCount As Integer = 0
theUFSession.UiOnt.AskSelectedNodes(iNodeCount, tSelectedNodes)
If iNodeCount > 0 Then
	For Each tNode As Tag In tSelectedNodes
The user must select the objects in the ONT before your dialog is started, this works best.
Have you tried:
Try
	'Post Process
	If IO.File.Exists(sFileName) Then IO.File.Delete(sFileName)
	theSession.Parts.Work.CAMSetup.Postprocess(theNcGroups, sPostName, sFileName, CAM.CAMSetup.OutputUnits.PostDefined)
Catch E As Exception
	Failure = E.Message
	' or Failure = E.ToString()
End Try
ToSting() will give you the entire text of the exception not only the caption.
Although NX10 seems somewhat better in giving you the real error, a lot of time when there's an error in the post, you just get an "error in do_event" message.  If this happens, to see what the REAL error is, you have to look in the log (syslog) file (help -> log file).
Did you look at RenameOperationsOntSelection.vb?
Mark Rief
Retired Siemens
Hello everyone,
I was on vacation and then out of office.
It is working now, I was struggling with a last error, but found what I was doing wrong.
I tried this:
Dim selectedTags() As NXOpen.Tag = Nothing
Dim selectedCount As Integer = 0
theUfSession.UiOnt.AskSelectedNodes(selectedCount, selectedTags)
Dim selectedObject As CAM.CAMObject = Utilities.NXObjectManager.Get(selectedTags(0))
Dim selectedObjects() As CAM.CAMObject = Nothing
selectedObjects(0) = selectedObject
workPart.CAMSetup.Postprocess(selectedObjects, PP, FromPath & "\Postlauf.TAP", CAM.CAMSetup.OutputUnits.Metric)
...which throws me an "Object not instanced..." error.
But found out:
Dim selectedObjects(0) As CAM.CAMObject
selectedObjects(0) = Utilities.NXObjectManager.Get(selectedTags(0))
Is working perfectly Smiley Happy
