How to get the automatic Element size within Mesh dialogs? (CAE)
Hi all,
is there a possibility to get the automatic Element size for a selected object like a polygon body?
In other words I would like to automate the little yellow flash in the tetrahedral mesh dialog.
Does anyone know how to do this or at least is there a workaround?
Best regards,
MGeyer
Re: How to get the automatic Element size within Mesh dialogs? (CAE)
Siemens Legend Siemens Legend
Siemens Legend
Hi MGeyer,
you get the Auto Mesh Size using the following UF Function:
NXOpen.UF.Sf.GetAutoElementSize(numObjects,objectsP)
with
  - numObjects (int) – No of bodies in objects_p array
  - objectsP (Tag) – list of bodies from which to calculate auto size
Returns the AutoSize as Integer,
Example:
        autoSize=theUFSession.Sf.GetAutoElementSize(1, bodytag)
Best Regards
Boris
Hi Boris,
thank you for your Answer!
Initially your Presentation about NX Open at the CAE Herbsttagung made me curious on how to do that, but I was not able to catch you for a short talk ;-).
Best regards,
MGeyer
