How to get the physical property table from selected mesh...
Hi Team,
How can I get the phycical property table associated with the selected mesh.
I need to find the associated physical property table to get the material properties.
NXOpen.CAE.Mesh tmpMesh = (NXOpen.CAE.Mesh)NXOpen.Utilities.NXObjectManager.Get(tempT);
string tmpString = tmpMesh.Name;
selectedmesh = tmpString;
NXOpen.CAE.IMeshCollector theMeshCollector123 = tmpMesh.MeshCollector;
Re: How to get the physical property table from selected mesh...
The physical prop table is assigned to the collector, not the individual mesh
Get the MeshCollector for the Mesh
Get the ElementPropertyTable from the MeshCollector (physPropTable in the code below)
Get the material table from the ElementPropertyTable
Dim materialTable As PhysicalMaterial = physPropTable.PropertyTable.GetPhysicalMaterialPropertyValue("material").Material
Hi Jim,
Thanks for the reply,
I trying to get the physical material in the same way what you told in NX-11, but it throwing an error showing property with this name could not be found.
NXOpen.CAE.PropertyTable x133 = theMeshCollector123.ElementPropertyTable;
NXOpen.PhysicalMaterial yy = x133.GetPhysicalMaterialPropertyValue("material").Material;
Did you query all of the properties in the x133 PropertyTable?
    Sub listPropTable(ByVal propTable As CAE.PropertyTable)
        For i As Integer = 0 To propTable.GetPropertyCount - 1
            Dim propName As String = propTable.GetPropertyNameByIndex(i)
            Dim propType As CAE.PropertyTable.PropertyType = propTable.GetPropertyType(propName)
            theLw.WriteLine("PropName: " + propName + "  Type: " + propType.ToString)
        Next i
    End Sub
