How to get the position of a point pointed by a Label
Hi, I am using NXOpen C++ for my project. Here is a Label pointing to the center point of the end of a cylinder, and how can I get the position of this point? When I use .AnnotationOrigin (), it returns me the position of the label, not the point I want.
Re: How to get the position of a point pointed by a Label
You have to get the LeaderData->Leader and use GetValue function to get the origin.
Look at this example on the solution center.  It is in C#.
https://solutions.industrysoftware.automation.siemens.com/view.php?sort=desc&q=leader+origin&dt=nx-a...
Suresh
Production: NX10.0.3 Developing: NX11.0.2.7, NX12.0.2, NX1847,
Development: C++, C# .Net, VB .Net, KF
But I cannot get Leader because there is no such class like LabelBuilder for me to find the leader, so how can I get Leader objects?
A DraftingNoteBuilder object will give you access to the leader data.
I get it, thank you very much!!!
