How to get the text from a coordinate note using NX Open C++
How can I get the text from a coordinate note, for example, I want to get the text "MARK THIS END", first I need to get all the coordinate notes, and then I need to judge which one has the text "MARK THIS END" , but I just don't know how to get the text
Re: How to get the text from a coordinate note using NX Open C++
Hi Jister,
here is an example VB code that should work, assuming that your text is the Suffix Label:
Dim theSession As NXOpen.Session = NXOpen.Session.GetSession()
Dim thePart as Part = CType(theSession.Parts.BaseDisplay,Part)
  For Each Annobj As Annotations.Annotation In thePart.PmiManager.PmiAttributes
    Dim myCNote As Annotations.CoordinateNote = Nothing
    myCNote = TryCast(Annobj, Annotations.CoordinateNote)
    If IsNothing(myCNote) Then
        Continue For
    End If
    Dim thebuilder As Annotations.CoordinateNoteBuilder = thePart.PmiManager.PmiAttributes.CreateCoordinateNoteBuilder(myCNote)
    Dim CNSuffixLabel As String = thebuilder.StringSuffixLabel
    If CNSuffixLabel.Equals("Test") Then
         'do something
        MsgBox("found!")
    End If
    thebuilder.Destroy()
Next
Using these routines should also be possible in C++
regards,
MGeyer
