How to get visible points in Drawing
Builder
Builder
I have created one view with multiple points in it.
Some of them are hidden and some of them are visible.
So how to get only visible points from active view?
Re: How to get visible points in Drawing
One solution would be to use the .AskVisibleObjects method then iterate through the returned objects, looking for point objects.
Hi Bhavik,
Please follow the below code.
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
For Each MyPoint As Point In workPart.Points
If MyPoint.Visibility = SmartObject.VisibilityOption.visible Then
msgbox("got you")
'Do your stuff....
End If
Next
Hope it helps.
Abhi
Hi Bhavik,
yes, Hope I got the solution.
try this,
For Each po As Point In workPart.Points
If po.IsBlanked = False Then
MsgBox("got you")
'Do your stuff....
End If
Next
Please let me know if it works,
Abhi
Builder
Builder
Hi Cowski,
Thanks for the help.
Now i am getting required result.
Builder
Builder
Hi Abhi,
yes, your method is also working as expected.
And I have used below method.
Dim tempPoint As Point
Dim DispObjs() As DisplayableObject
DispObjs = View.AskVisibleObjects()
For Each tempobj As DisplayableObject In DispObjs
If TypeOf tempobj Is Point Then
tempPoint = tempobj
' MsgBox(tempobj.Name)
End If
Next
