How to import a part file in C
I am trying to import a .prt file and merge it into the current Work Part, using c.
The plan is to take the object features of this file and use them to the current work part.
Tried to use UF_PART_import but it doesn't work.
Thanks in advance
Re: How to import a part file in C
Did you get an error message; and if so, what did it say?
Yes I did: Memory access violation.
Can you "File -> Import" that same part interactively?
This worked fine for me:
char
    *fName = {"D:\\_NX10\\_Parts\\PartToImport.prt"};
UF_import_part_modes_t
    modes = { 0, 0, 0, 0, 1, TRUE, FALSE };
double
    destCsys[6] = { 1., 0., 0., 0., 1., 0. },
    destPnt[3] = { 10., 10., 10. },
    scale = 1.0;
tag_t
    theGroup = NULL_TAG;
UF_CALL(UF_PART_import(fName, &modes,destCsys, destPnt, scale, &theGroup));
UF_CALL(UF_VIEW_fit_view(NULL_TAG, 0.9));
NOTE:  If you are trying to import into a drawing, change the fifth element of "modes" from 1 to zero.
That helped a lot. Thank you!
From the UF_PART_ import(filename,&modes,dest_csys,dest_point,scale,&group), how can I delete the dest_csys that is displayed?
Thank you
Dora
Every time I import a part, the datum of the part is displayed. Is there any way of suppressing, hiding or deleting it?
Thank you
Dora
You can use the normal UF routines to hide it (as you already have the tag from "dest_csys").
If it is a different CSYS (e.g. from the part you import) you can set up the part to import with it on a different layer, and when you import the part, maintain the original layers?
Hello Ken,
Thanks for your help. I don't have the tag from the csys. Csys is double variable. Any ideas?
Dora
