How to lauch a Winform dialog from a UI Block Styler dialog?
I have a winform dialog with one button on it and another dialog created by Block UI Styler.
Now I want to achieve the followings,
  1. When I click the button on the winform dialog, the dialog created by Block UI Styler need to show up.
  2. When I click OK or Cancel button of the dialog created by Block UI Styler, the winform dialog comes back.
Is the above possiblt?
Re: How to lauch a Winform dialog from a UI Block Styler dialog?
Hi Bruce_Qin,
let's say you have 2 classes:
- GUI (your Winform)
- NXDiag (your UI Block Styler dialog)
What you can do is using 'show' and 'hide' methods:
Class GUI
void showUIBlockStyler(){
NXDiag myNewDialog = new NXDiag(this);
this.hide();
myNewDialog.show();
 Now your Winform will hide and the NXDialog will pop up.
Class NXDiag
private GUI myReferenceToWinForm
void NXDiag(GUI myCaller){
myReferenceToWinForm = myCaller
public int apply_cb(){
// do something
myReferenceToWinForm.show()
In the constructor you have to set a reference to the GUI.
In the method apply_cb you have to do whatever you want to do with your BlockStyler and after
doing that just say 'show' to the GUI.
Hope that helps!
Bye,
Flo
Thanks a lot,Flo!
