How to launch NX Extrude command from UIStyler
I have this requirement to lauch Draft Analysis command through code from the UIStyler's callback.
I was looking for similar and found in the NX itself you can do that.
Please refer this example to understand what i want
Goto->Menu->Analysis->Molded Part Validation->Check Regions
Once Check Regions command opens then goto Face tab. At the botton of UI you should see Draft Analysis
And when you click on this command it internally launches the same Draft Analysis which exists at
Goto->Menu->Analysis->Shape->Draft Analysis
Do we have something like power command window where i put the name of the command and command dialog window opens. similar to shortcut keys where you keyin X and extrude command dialog opens
Appreciate your support
Re: How to launch NX Extrude command from UIStyler
Native NX dialogs cannot be invoked from a NX Open application.
Thank you Jim
