Do you mean
Reply
How to launch WPF appliction in NX
Hi All,
So far we have used C# windows forms application to create an nxopen appl.
i have a requirement to use wpf insted. i am able to launch the applciation inside NX using
.ShowDialog() method. as this way will lock access to nx, so i am looking at an equivalent of Application.run() as in windows forms application.
FL
Re: How to launch WPF appliction in NX
In WPF project you create WPF Window and then call method Window.Show() instead Window.ShowDialog(). You can also use Window.Show(IWin32Window ownerWindow) to prevent hiding window when activate NX Main Window.
