cancel
How to launch and run CheckMate with Journal
I am trying to learn how to create a journal in VBA.NET that will accept input of a  model and launch and run a certain CheckMate test on the Assembly. I am trying to skip the step of having to load the model part into NX and then run CheckMate on it.
I would like to be able to just input the model DB number and have the journal load the assembly for me, and then run the checkmate test for me as well.
I am running TeamCenter and I am using NX 9.0.3.4
Betreff: How to launch and run CheckMate with Journal
we use
ug_check_part -apply_load_options -checker GIRA -output_file "%errorfile%" "%partfile%"
to check a part against our CAD standard.
This is a commandline tool.
After checkmate run we search for "passed" in the logfile.
Mit freundlichen Grüßen / With kind regards
i.A. Dipl.-Ing. (FH) Stefan Walder
CAD Management
stefan.walder@gira.de
Tel +49(0)2195-602-319, Fax +49(0)2195-91603-319
Gira Giersiepen GmbH & Co. KG, Elektro-Installations-Systeme
Industriegebiet Mermbach, Dahlienstraße, 42477 Radevormwald, Deutschland
Intelligente Gebäudetechnik von Gira. www.gira.de
Handelsregister AG Köln HRA 16352
Persönlich haftende Gesellschafterin: GAV Management GmbH,
Handelsregister AG Köln HRB 50479
Geschäftsführer: Dipl.-Kfm. Dirk Giersiepen, Alfred A. Bulitz,
Dipl.-Kfm. Thomas Musial
Gira Giersiepen GmbH & Co. KG, Electrical installation systems
Industriegebiet Mermbach, Dahlienstraße, 42477 Radevormwald, Germany
Intelligent building technology by Gira. www.gira.com
Register of Business Names: AG Köln HRA 16352
Partner Personally Responsible: GAV Management GmbH,
Register of Business Names: AG Köln HRB 50479
Managing Directors: Dipl.-Kfm. Dirk Giersiepen,
Dipl.-Wirtschafts-Ing. (FH) Oliver Borchmann, Alfred A. Bulitz,
Okay, so what does GIRA mean? How would I define what test to run in CheckMate?
Okay that's not clear to you.
We build a check profile called "GIRA". With this profile we check out parts.
In NX we use the environment variable UGII_CHECKMATE_DEFAULT_CHECKER=GIRA.
CAD Management
