How to make ribbon tab active or current shown tab through C API
Hi Every one,
How to make ribbon tab active or current shown tab through C API.
I am creating ribbon tab called “TabA” at the start of NX using .rtb file. From this ribbon tab, when a button is clicked I will create another ribbon “TabB” using API UF_UI_create_ribbon (). But this new tab “TabB” won’t become active or shows until user click on this tab, NX window still will be showing “TabA”.
I tried using UF_UI_set_ribbon_vis, it is not making tab active or current
Thanking you
Nij
Re: How to make ribbon tab active or current shown tab through C API
PLM World Member Pioneer PLM World Member Pioneer
'UF_UI_set_ribbon_vis' API used to set the ribbon tab visiblity (SHOW / HIDE) in the session. There are no API's or method available to set the 'TabB' to active or as current shown by programmatically. You can raise a ER for that.
