How to make the transient text parallel to the screen like the PMI note?
Siemens Pioneer Siemens Pioneer
Siemens Pioneer
I use TransientText method to create some transient notes in the view. However, the notes can be created on X-Y plane only based on the absolute coordinate. Anyone knows how to set it so that they can display always parallel to the screen?
3 REPLIES 3
Re: How to make the transient text parallel to the screen like the PMI note?
The .DisplayTemporaryText method may do what you want.
Siemens Pioneer
I am using C++ coding NXOpen. I can't find this method in the class member list. is there something I missed?
Here's the link to the C version:
https://docs.plm.automation.siemens.com/data_services/resources/nx/1847/nx_api/custom/en_US/ugopen_d...
There might be a C++ version. If not, you might be able to make use of the C version.
