How to only select all objects in the layer?
    we use mask to change the selectable status associated with a particular object type to valid or invalid in grip.Regardless of whether the object has been hidden, how to only select all objects in the layer 1 and layer 3 and make it all displayed in grip.
Re: How to only select all objects in the layer?
It's a long time since I used GRIP. So this is just a hint:
$$ Search for POINTs on layer 1
ENTITY/ELE
BLANK/ALL $$ Blank all
INEXTE/ALL,WORK
   ELE=NEXTE/IFEND,LDONE:
   IFTHEN/&TYPE(ELE) == 2 AND &LAYER(ELE) == 1 $$ if point on layer 1
      UNBLANK/ELE $$ Unblank point
   ENDIF
LDONE:
Hope this helps
Herbert Macho
EBNER Industrieofenbau
AUSTRIA
NX 12.0.2.9 (TeamCenter11 and Native)
