How to read Teamcenter preference from NX Open Code
Hello Experts,
Can we read the Teamcenter preference from NX open code. Is there any API available in UF_UGMGR Functions to read TC preference from NX open.
Thanks.
Re: How to read Teamcenter preference from NX Open Code
hi
I'm not quite sure what you mean by "Teamcenter preference " ,
but in "uf_ugmgr.html" all the good stuff is described in a good manner .
lklo
You can use invoke PDM server call API which will execute Teamcenter ITK code. ITK can read Teamcenter preference and return its value. I am not sure if there is any direct API which can give you Teamcenter preference value.
This might be 4 year late but here you go. This is a method that gets a preference service and grabs the last value for a specified preference:
Service:
  public static Teamcenter.Services.Strong.Administration.PreferenceManagementService PrefService
            get
             return Teamcenter.Services.Strong.Administration.PreferenceManagementService.getService(TCSession.GetConnection());
Method:
        public static string GetSitePreference(string preferenceName)
            Teamcenter.Services.Strong.Administration._2012_09.PreferenceManagement.GetPreferencesResponse preferenceResp =
                 TCProgram.PrefService.GetPreferences(new[] { preferenceName }, true);
            return preferenceResp.Response.LastOrDefault().Values.Values.LastOrDefault();
