Do you mean
Reply
How to retrieve Material Orientation from a mesh Element
Hi all,
Does anyone know how to retrieve in NXOpen the material orientation of a mesh element?
Best Regards,
Roberta
Re: How to retrieve Material Orientation from a mesh Element
This can be done via CAE.ModelCheck.ElementMaterialOrientationCheckBuilder. The DoCheck() method will return an array of vectors that depend on the settings (a single vector for shells, and one, two or all 3 vectors for solids).
Record a journal of the process of doing a material orientation check to see the code.
