How to run external java app?
Siemens Creator
I wrote java app for nx.
I try to run this app externaly (witout load nx) but no success.
I saw there is a nxopen example for java which introduces how to use nx remote with java RMI,
this example has two mode option -
1) Batch mode
2) Interactive mode
The second option is run properly but it requires loading NX.
The first option dosn't  requires loading NX (that what i looking for), but she fails to run.
I'd be happy if someone can help me understand how to run correctly external java app that not requers NX load........
I already spent many hours to understand it by myself.
Thanks a lot Smiley Happy
Re: How to run external java app?
Be sure you are in an NX Command Prompt so that your variables are assigned correctly.
Be sure JAVA_HOME is set correctly.
Then you need a command line something like this, assuming your executable is named "program.jar":
java -cp ".;program.jar;%UGII_ROOT_DIR%\NXOpen.jar;%UGII_ROOT_DIR%\NXOpenUF.jar;%UGII_ROOT_DIR%\NXOpenUI.jar" program.jar
(That should have all been on one line; in my browser is looks like it has been broken in two.)
Hi Steve,
I was trying to execute jar file through batch mode. I have ran it as you have mentioned in this post. But i am getting an error saying Error: Could not find or load main class NXInfo_1.jar. Kindly help. Thanks in advance.
Raghav
