How to select only "Part List" in c#.
I want to select only part list and not other component in drafting mode or in modeling.
But my assemebly is able to select all i.e. it select component as well as part list. But i want to validate only for "Part List" selection in drafting mode.
Main File ....
theProgram = new Program();
//TODO: Add your application code here
Part selectedPart = null; utils.selectComponentWithPart(theUI, "Select Part List", ref selectedPart); if (selectedPart == null) { return retValue; }
// Function public Selection.Response selectComponentWithPart(UI theUI, string prompt, ref Part obj) { //NXObject selobj; TaggedObject selobj; UI ui = theUI; Selection.MaskTriple[] mask = new Selection.MaskTriple[1]; { mask[0].Type = UFConstants.UF_component_type; mask[0].Subtype = UFConstants.UF_component_subtype; //mask[0].SolidBodySubtype = UFConstants..UF_UI_SEL_FEATURE_BODY; } Point3d cursor = default(Point3d); Selection.Response resp = ui.SelectionManager.SelectTaggedObject(prompt, prompt, Selection.SelectionScope.AnyInAssembly, Selection.SelectionAction.EnableSpecific, false, false, mask, out selobj, out cursor); if (resp == Selection.Response.ObjectSelected | resp == Selection.Response.ObjectSelectedByName) { obj = (Part)((NXObject)NXOpen.Utilities.NXObjectManager.Get(selobj.Tag)).OwningPart; return Selection.Response.Ok; } else { return Selection.Response.Cancel; } }
Re: How to select only "Part List" in c#.
Thanks Cowski1
This is really helpfull.
I also did like this... Thanks.
Type varTypeOfObject = null;
TaggedObject selobj = null;
utils.selectComponentWithPart(theUI, "Select Part List", ref selectedPart, ref varTypeOfObject, ref selobj);
NXOpen.Tag tempTag = Tag.Null;
// This tempTag is a selected partlist id.
theUfSession.Obj.CycleObjsInPart(selectedPart.Tag, UFConstants.UF_tabular_note_type, ref tempTag);
Int32 type;
Int32 subtype;
theUfSession.Obj.AskTypeAndSubtype(tempTag, out type, out subtype);
if (subtype == UFConstants.UF_parts_list_subtype)
                  theUfSession.Plist.Update(tempTag);
                  theUfSession.Plist.AskObjects(tempTag, out objectnum, out objects);
public Selection.Response selectComponentWithPart(UI theUI, string prompt, ref Part obj, ref Type varTypeOfObject, ref TaggedObject selobj)
            UI ui = theUI;
                varTypeOfObject = selobj.GetType();
            else
