How to start NX in Batch mode
Builder
Builder
How to start NX in a background and it is not visible to any user?
Re: How to start NX in Batch mode
See "Executing Batch Applications" in the NX Open Programmers Guide
https://docs.plm.automation.siemens.com/tdoc/nx/11/nx_api/#uid:xid1162445:index_nxopen_prog_guide:id...
set UGII_USER_DIR="Set your current working Folder"
call "C:\Siemens\NX100\UGII\ugraf.exe"
::Smiley SurprisedPTIMUS_PRIME
Builder
Builder
I know this solution.
My problem is that i want to run NX in background and it is not visible to user.
I want to convert .catprt to .jt model.
Builder
Builder
I am trying the method as mentione by siemens but getting error as shown in attached image.
https://docs.plm.automation.siemens.com/tdoc/nx/10/nx_help#uid:index_ugcatia5:xid463626:xid458471
Is there any information in the testfile_CATPart.log file?
Builder
Builder
Yes logfile is there.
please find the attachment.
Not much to go on there. I would suggest contacting GTAC at this point.
Builder
Builder
please also find the attached image for one more error.
Don't know what does that mean ?
I tried by using catiav5.exe file from NX9 and NX 11.
This means that your PATH is not defined correctly.
Any NX command line application should be launched from a NX Command Prompt to ensure that the environment is set up correctly. Use Start, All Programs, Siemens NX##, Tools, Command Prompt to open a NX command prompt.
If you are writing batch scripts, you need to be sure to set up the environment properly by calling ugiicmd.bat properly first. Examine the properties for the start menu shortcut referenced above for syntax:
C:\Windows\System32\cmd.exe /k ugiicmd.bat "C:\apps\Siemens\NX\11.0"
