How to turn on assembly filtering in the assembly navigator by VB
Builder
Builder
we want to turn on the assembly filtering mode in the assembly navigator by via visual basic code. The reason is, that we will load assembly standard-filters with a bookmark-file (PMLXML). But this works only, if the user has turned on assembly filtering prior. We still have a VB for loading that bookmark-file. But in the past some users had forgotten to turn on assembly filtering mode.
Do anyone know how to turn it on by VB?
Michael
Michael Eichelberg, CAD-Consultant, Dr. Wallner Engineering Nord GmbH
Production: NX10.0.3 MP16, NX11.0.1 MP4
Development: Batch and VB Testing: NX12
Re: How to turn on assembly filtering in the assembly navigator by VB
I'm not sure that it is possible to turn on an assembly filter with the NXOpen API, I doubt that it is. The API doesn't give you much control over the navigators.
Perhaps an NX macro would serve your needs better.
