cancel
How-to-turn-the-display-off using VB .NET
Similar to the following discussion (How-to-turn-the-display-off C ) I want to turn the display of while updating a CAE model.
Dim theUFSession As UFSession = UFSession.GetUFSession()
theUFSession.Disp.SetDisplay(UFConstants.UF_DISP_SUPPRESS_DISPLAY)
... Code to execute without screen update
theUFSession.Disp.SetDisplay(UFConstants.UF_DISP_UNSUPPRESS_DISPLAY)
theUFSession.Disp.RegenerateDisplay()
This however does not stop the screen updating.
Re: How-to-turn-the-display-off using VB .NET
Have you tried calling the functions used in the other answer you referenced:
UF_DISP_set_display(UF_DISP_SUPPRESS_DISPLAY);
// do some work
UF_DISP_set_display(UF_DISP_UNSUPPRESS_DISPLAY);
UF_DISP_refresh();
// or call
UF_DISP_regenerate_display();
These functions (or their equivalents) can be called from VB code. They are in the NXOpen.UF class.
山田
yamada
