How to turn the display off?
How can I turn the display off and keep the analysis happening at the same time?
I am using C.
Thank you,
Dora
Re: How to turn the display off?
UF_DISP_set_display(UF_DISP_SUPPRESS_DISPLAY);
// do some work
UF_DISP_set_display(UF_DISP_UNSUPPRESS_DISPLAY);
UF_DISP_refresh();
// or call
UF_DISP_regenerate_display();
Production: [NX8.5.3.3 MP11 64bit] Testing: [NX12.0.0.27 MP1]
hi to all, i try to use this:
it works fine in my first automation but don't work in the second automation. I could not understand why....
in second automation the function return 110500 while in the first 0. This indicates that for my second automation function fails.
help me please
With an extra zero (1105000) this is the UF_err_program_not_initialized error. Are you sure your program is properly initialized?
Jan
Jan Böttcher
The error is 1105000.
I initialize application whit UF_initialize() method in constructor and UF_terminate() in destructor. Is this the correct way?
I also tried to see status with UF_is_initialized() and return true.
i ask also the status of display with UF_DISP_ask_display(&status) and before the UF_DISP_set_display(UF_DISP_SUPPRESS_DISPLAY) is 1, while after is 0.
it seems to work fine but i continue to see ghapics modification and 'Work in progress...' window
So your second program does not end up with an error any more?
As for the UF_DISP_set_display funktion: I don't know your program but according to the documentation and my experiences this function does not surpress all graphic output.
Jan
Jan Böttcher
