Icons on Ribbon Tab
Hi everyone!
I'm using NX 10.0 and writing an add-in. All is great except icons. When I draw icons with white background NX applies a grayscale filter to them and they become gray. When you move the mouse on icons, they become white as it was designed. How can I solve this problem? I need white background on my icons.
As I understood only *.bmp files could be set as icons on ribbon tab, but bmp format doesn't support transparency.
I found NX gallery database files with the extension *.bma, but couldn't open them. Does NX standard icons have some "specific" color which substitutes as transparent by the system?
Aleh Nasan.
Re: Icons on Ribbon Tab
I've not customized the ribbon in NX9, but in NX8.5 MAGENTA is used for transparency (R,G,B = 255,0,255)
Production: [NX8.5.3.3 MP11 64bit] Testing: [NX12.0.0.27 MP1]
In NX you will have to use two icons to specify transparency, this is described in the NX documentation about customizing the tool bars.
One BMP has a white background and one has a black one where you need transparency, so the black background is the mask.
The documentation on icons in the UI is here
Mark Rief
Retired Siemens
How have I never seen this before? Man LOL
You didn't RTFM? ;-)
Sometimes they do a good job of hiding things in plain sight
R'ingTFM is for babies Man Tongue
However, on this occasion my will did bend a little and I've bookmarked it Man Embarassed
LOL Graham - it happens to the best of us :*) @Inch and @Ken_A - there is a lot of good information burried in the help, and I agree it's not always easy to find. Search is now your friend.
Having discussed this several times with our TDOC staff, I learned that I was a "browser" - meaning I look through the table of contents. But with the new search engine, I have converted to a "searcher" - meaning I use search. It really is much better now, if you have not tried it.
Mark Rief
Retired Siemens
I'm still on NX8.5 and searching the docs for me is still plagued with Java issues.
However, I just tried searching the online docs for NX10 and that works well and really fast.
Maybe I'll start using that for searching and then cross reference the NX8.5 docs to be sure.
Cool! Can we also use gray for semi transparent Icons?
