ImportIges with UT-8 Path
I'm trying to import iges files programatically from UT-8 Pathes (with Chinese letters..)
I'm using the NXOpen::IgesImporter and I set the path through NXStrings:
igesImporter->SetInputFile(NXString( NXString str (m_igesFilePath, NXString::UTF8));
However igesImporter->Commit() is failing whenever my path contains any Chinese characters.
Is their any solution for this problem?
best regards,
Felix
Software Engineer PLM/ CAD
...using NXOpen with C++
Re: ImportIges with UT-8 Path
Esteemed Contributor
Non ANSI encoded paths are only supported starting with NX 10, previous releases of NX don't support them.
What NX release are you using?
Production: NX10.0.3, VERICUT 8.1, FBM, MRL 3.1.4 | TcUA 10.1 MP7 Patch 0 (10.1.7.0) | TcVis 10.1
Development: VB.NET, Tcl/Tk Testing: NX12.0 Preparing: NX12.0
Thanks for your replay.
Of course I'm using NX 9 at the moment. I will test it with NX10
best regards,
Felix
if anybody is interested...
I'm just moving the files with nonANSI characters to a tmp ansi location and then perform the iges import. A simple and easy solution which is working nicely.
Properties and names of the imported features are filled by NXStrings with UTF8 coding.
best regards,
Felix
