Instance vs. Occurrence
Hello everyone!
I studied the documentation on the assemblies in NX, but I still not 100% about the instance vs. occurrence question. I don't understand the role of each - maybe I missed something. It's more or less clear of occurrence is, but not quite clear what is instance. Could you please try explain?
Re: Instance vs. Occurrence
Stefan_Pendl 3rd Gear
3rd Gear
The occurrence is the component and the instance is the connection between the component and the parent.
One component (occurrence) can have multiple instances (positions), so in a car the wheel component has four instances.
Production: NX10.0.3, VERICUT 8.1, FBM, MRL 3.1.4 | TcUA 10.1 MP7 Patch 0 (10.1.7.0) | TcVis 10.1
Development: VB.NET, Tcl/Tk Testing: NX12.0 Preparing: NX12.0
I thought that number of occurrences equal the number of instances. Is it wrong? At least I seem to be able to obtain the same number both for instance and occurrence.
3rd Gear
See the SNAP getting started guide section about assemblies for further information.
I know this manual. The instance is exactly what is NOT covered there. Or at least I missed that completely.
3rd Gear
Then you might want to take a look at the NXOpen C assemblies API guide, see the terminology and automobile example pages.
Looked at that one too, thanks. I more or less understand what instance is, but not 100%. Although I was able to use both instance and occurrence.
3rd Gear
If I am not mistaken, instances are not directly used in NXOpen .NET, everything is done through the component object.
It makes things much easier, if you have to deal with only one object instead of two.
Instance can be obtained and acted upon in NX Open .NET. For example, you may change its name. This is exactly what I did recently to work around some bug in NX8.5.
