Is part a component of another part
Is there a simple way of finding if a part in the session is a child/component of another part?
Currently I'm having to get all components of each part in the session and then lookup if the part of interest is in the my list of known components which seems a little long winded.
Re: Is part a component of another part
There should be Information => Assemblies => Where used, which you could try to record a journal of.
Are you concerned with just the parts in the session, or anywhere?
TC or Native?
If anywhere/native, you could use the ugpc.exe on all files & parse the output
If anywhere/TC, where used can show things (may assume PSE is correct for all parts)
Hi Stefan,
Thanks for your suggestion.  I've given that a go but it's not supported (at least in NX8.5 that I'm running)
I was thinking along the lines of getting the occurance of the part or casting the part to a component to allow me to then get the parent.
I'm only interested in the parts in the session.
At the moment this is what I'm doing:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Assemblies
Imports System.Collections.Generic
Module Module1
    Dim comp_list As New List(Of String)
    Dim parts_list As New List(Of String)
    '  Explicit Activation
    '      This entry point is used to activate the application explicitly
    Sub Main()
        Dim ufs As ufsession = ufsession.getufsession()
        Dim theUI As UI = UI.GetUI()
        Dim lw As ListingWindow = theSession.ListingWindow
        lw.Open()
        For Each my_part As Part In theSession.Parts
            parts_list.Add(my_part.FullPath)
            Dim ca As ComponentAssembly = my_part.ComponentAssembly
            Try
                Walk(ca.RootComponent, 0)
            Catch ex As Exception
            End Try
        Next
        For Each my_part As String In parts_list
            If comp_list.Contains(my_part) Then
            Else
                lw.WriteLine(my_part)
            End If
        Next
    End Sub
    Sub Walk(ByVal c As Component, ByVal level As Integer)
        Dim children As Component() = c.GetChildren()
        Dim child As Component
        Dim prototype As Part
            For Each child In children
                Dim child_part As Part
                If TypeOf child.Prototype Is Part Then
                    child_part = CType(child.Prototype, Part)
                    comp_list.Add(child_part.Leaf)
                End If
                Walk(child, level + 1)
            Next
     End Sub
End Module
This shows the parts that are top level assys, which is ultimately what I'm trying to achieve.
Have you tried using this:
UF_ASSEM_where_is_part_used
It sounds like it could be just what you need.
Note that there are VB/C#/Java wrappers for it.
Production: [NX8.5.3.3 MP11 64bit] Testing: [NX12.0.0.27 MP1]
