Issue in assigning a calculated weight to top level assembly in TC integrated NX with UF_Attr_Assign
Hi All,
We have just migrated from NX 7.5 to NX10. Few of our customised tool's with respect to assigning weight value to an attribute called [CALC_WT] to a top level assembly in NX is failing.
we have used NX_Attr_Assign function to do it, but now it is throwing warning message
showing "THIS IS A RESERVE ATTRIBUTE". How can i overcome this issue. any work around or direct solution is greatly appreciated.
FLL
Re: Issue in assigning a calculated weight to top level assembly in TC integrated NX with UF_Attr_As
As far as I know it is no longer possible to write to internal reserved attributes anymore as it was possible until NX 8.5 Smiley Sad
You will have to use an attribute of your own now.
