Issue in deleting Balloons.
Hi All,
I am performing a functionality to delete all my triangle balloons in drawing sheet.
I am able to get triangle balloons but I am not able to delete it.
PFB code. Line hilighted in Bold is the line i am facing exception.
Sub CollectAutoBalloons(ByRef theList As List(Of Annotations.IdSymbol), ByRef sample2 As String)
Dim myIdBuilder As Annotations.IdSymbolBuilder
Dim objects1(0) As NXOpen.TaggedObject
For Each tempID As Annotations.IdSymbol In theSession.Parts.Work.Annotations.IdSymbols
Dim theCallout As Tag = Nothing
theUfSession.Drf.AskCalloutOfAnnotation(tempID.Tag, theCallout)
If theCallout = Tag.Null Then
End If
myIdBuilder = theSession.Parts.Work.Annotations.IdSymbols.CreateIdSymbolBuilder(tempID)
sample2 = myIdBuilder.BalloonType()
If (sample2 = "3") Then
objects1(0) = myIdBuilder
theSession.UpdateManager.AddObjectsToDeleteList(objects1)
Dim notifyOnDelete2 As Boolean = Nothing
notifyOnDelete2 = theSession.Preferences.Modeling.NotifyOnDelete
End If
myIdBuilder.Destroy()
Next
End Sub
At the line Add objects to delete list I am facing exception.
Internal Error- Memmory access violation
Can anyone please help.
Thanks in advance
5 REPLIES 5
Re: Issue in deleting Balloons.
shouldn't you delete the symbol itself and not the builder object?
maybe try the following:
If (sample2 = "3") Then objects1(0) = tempID theSession.UpdateManager.AddObjectsToDeleteList(objects1)
'and before "End Sub" don't forget to do:
theSession.UpdateManager.DoUpdate(theSession.NewestVisibleUndoMark)
regards,
MGeyer
Never delete a member of a collection while you are iterating through said collection. Doing so will lead to errors and/or unexpected behavior. In this case, I'd suggest creating a list of ID symbols, iterating through the ID symbol collection and if you want to delete it, add it to the list. When the loop completes, add the items from the list to the NX delete list and perform a .DoUpdate. Something like below (pseudocode):
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "delete stuff")
Dim idSymbolsToDelete as new list(of Idsymbol) for each tempID as idsymbol in workpart.idsymbols if tempID = garbage then idSymbolsToDelete.Add(tempID) end if next
theSession.UpdateManager.AddToDeleteList(idSymbolsToDelete.ToArray)
theSession.UpdateManager.DoUpdate(markId1)
Hi All,
Thank you very much for the reply. I've modified the code as suggested I've got my exception cleared.
But I did not met my requirement.
This is how I modified my code. I did not get any error or exception.
My code have run fine.
But Triangular balloons were not deleted.
Sub CollectAutoBalloons()
        Dim objects1() As NXOpen.TaggedObject = Nothing
        Dim iCounter As Integer = 0
        Dim idSymbolsToDelete As New List(Of NXOpen.TaggedObject)
        Dim sample2 As String = String.Empty
        Dim markId2 As NXOpen.Session.UndoMarkId = Nothing
        markId2 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Visible, "Delete")
            End If
            End If
            'myIdBuilder.Destroy()
        Next
        theSession.UpdateManager.AddObjectsToDeleteList(idSymbolsToDelete.ToArray)
        Dim nErrs2 As Integer = Nothing
        nErrs2 = theSession.UpdateManager.DoUpdate(markId2)
    End Sub
So I've recorded a journal and executed the same one. It is not deleting the Triangular balloons. I tried to modify the journal code as per my logic and executed it as shown below.
But it did not delete. I did not get any exceptions or errors.
        ''   Menu: Edit->Delete...
        'Dim myIdBuilder As Annotations.IdSymbolBuilder
        'Dim sample2 As String = String.Empty
        'For Each tempID As Annotations.IdSymbol In theSession.Parts.Work.Annotations.IdSymbols
        '    myIdBuilder = theSession.Parts.Work.Annotations.IdSymbols.CreateIdSymbolBuilder(tempID)
        '    sample2 = myIdBuilder.BalloonType()
        '    If (sample2 = "3") Then
        '        Dim markId1 As NXOpen.Session.UndoMarkId = Nothing
        '        markId1 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Invisible, "Delete")
        '        Dim notifyOnDelete1 As Boolean = Nothing
        '        notifyOnDelete1 = theSession.Preferences.Modeling.NotifyOnDelete
        '        theSession.UpdateManager.ClearErrorList()
        '        Dim markId2 As NXOpen.Session.UndoMarkId = Nothing
        '        markId2 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Visible, "Delete")
        '        Dim objects1(0) As NXOpen.NXObject
        '        Dim idSymbol1 As NXOpen.Annotations.IdSymbol = CType(workPart.FindObject(tempID.JournalIdentifier), NXOpen.Annotations.IdSymbol)
        '        objects1(0) = idSymbol1
        '        Dim nErrs1 As Integer = Nothing
        '        nErrs1 = theSession.UpdateManager.AddToDeleteList(objects1)
        '        Dim notifyOnDelete2 As Boolean = Nothing
        '        notifyOnDelete2 = theSession.Preferences.Modeling.NotifyOnDelete
        '        Dim nErrs2 As Integer = Nothing
        '        nErrs2 = theSession.UpdateManager.DoUpdate(markId2)
        '        theSession.DeleteUndoMark(markId1, Nothing)
        '    End If
        'Next
        ''   Menu: Tools->Journal->Stop Recording
Can anyone pls help me.
@Shashank1 wrote:
Hi All,
            End If
            End If
        Next
    End Sub
I'd suggest 2 modifications to the code. First:
End If
if myIdBuilder.BalloonType = NXOpen.Annotations.BalloonTypes.TriangleUp then
End if
The current code compares the balloon type (an integer) to a string value; this will always return false for the comparison. I suggest comparing to the named enumeration value (BalloonTypes.TriangleUp) as this will work and make your code intention clear and thus easier to maintain.
Second:
Uncomment this line of code. You definitely want to destroy the builder object when you are done with it. Not doing so will lead to errors or unexpected behavior. If you run the code and do not destroy the id symbol builder, you most likely won't be able to delete the triangle id symbols, even through the interactive NX commands. Update your code, restart NX and try it again.
Yes it is working if I use
Thank you very much.
