cancel
JAVA:Error as NXOpen User Function - Works from Command line
Hi there,
when I am executing the .class file of this java code as NXOpen User Function (File-> Execute-> NXopen...):
package testproject;
import java.io.File;
import nxopen.*;
import org.apache.poi.hssf.usermodel.HSSFWorkbook;
import org.apache.poi.poifs.filesystem.NPOIFSFileSystem;
public class Test
  public static void main(String [] args) throws Exception
     String xls_path = "C:\\MASTER.xls";
       NPOIFSFileSystem fs = new NPOIFSFileSystem(new File(xls_path));
       HSSFWorkbook wb = new HSSFWorkbook(fs.getRoot(), true);
        wb.close();
        fs.close();
  public static final int getUnloadOption() { return nxopen.BaseSession.LibraryUnloadOption.IMMEDIATELY; }
I am getting the error: "A JAVA exception was encountered" in NX. When I am running the .class file from command line - it works great. What am I doing wrong ?
Thanks in advance !
Re: JAVA:Error as NXOpen User Function - Works from Command line
You could try getting the NX session.  I realize you are not actually calling any NX Open methods, but maybe NX wants you to get the session when you run interactively.  I don't know for sure whether it will make a difference, but it would be a simple test.
