.JT export options and configuration file
Hello all,
I have used the forum many times but this go around I couldn't find a solution. So I'm running into an issue with our .jt files where the solids are being placed on a seperate component under an assembly item. I'm trying to get rid of it however I cant seem to find an option to control this feature. Neither in the export options or in the configuration file. Does anyone have the solution?
NX file structure
.jt file structure
Re: .JT export options and configuration file
Hi @Havoc35 ,
Try changing highlighted JT export setting shown in below image.
Maybe in your case it's set to 'As assembly and folder of parts'
Hope it helps.
Amol
