JT2NX program to generate prt from JT
Siemens Creator
I am new to NX open.
Can anyone provide a sample program to convert jt2nx ?
I found ootb dll called "JT2NX" which converts jt into .prt files.
This option is available using UI -when I open an assembly in NX (JT assermbly ) and hit save, it creates .prt files .
I would like to do the same with no GUI.
Any suggestions will be appreciated.
Thanks.
Re: JT2NX program to generate prt from JT
Siemens Creator
Thank you, really appreciate that. Program works perfect except it doesnt  understan long file names.
File name has underscores and dash .
Program does not find some of the files.
